I am working on Wireless power transfer modeling for the 20KW, @22kHZ application. I have following question.
1. What would be Thickness of cylinder (Vertical Height) of Litz coil with specifications of (Ø0.25*384),σ:=5.8e7 [S/m] (In eddy current simulation environment cylinder with stranded technique is used to give input current)
2.How to calculate R1 and R2 for ANSYS Simplorer equvilant circuit for the above-mentioned specs of Litz wire. Kindly share the method to uderstand the calculation.
3.If 60A current need to be given to the transmitter with 10 turns the amount of current should be 6 or 60 in the stranded exitation table.
Looking forward to your kind responses.
Kind regards
Ehsan Glani
