spman
Hi
I have a problem in SDK.
I create example programs such as Hello world, memory test and peripherals test with SDK for ML605 board (after creating hardware platform) . Then I try to program the FPGA from "Xilinx Tools-> Program FPGA". In the next window I should select the elf file of one of those programs. isn't it?
But only the memory test program works after programming the FPGA!
I tried other elf files but none of them worked. On the other hand, I selected bootloop instead of an elf file and then tried to run each of the programs from "Run as->Launch on Hardware" and all of them worked successfully.
What is the problem when I select an elf file to create a bit file and program with it?
Thanks in advance
Thanks in advance
