Synaps3
Member level 1
- Joined
- Oct 14, 2014
- Messages
- 37
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 358
I'm pretty new to PIC programming and I'm trying to interface an SD card with a PIC18F4685. I began by doing a simulation with proteus because I don't have the actual hardware yet. This PIC chip is a 5V and the SD card is 3.3V so I have this extra circuit:
The problem is this doesn't work in proteus unless the SD is directly connected to the PIC. I just want to confirm that this is needed in real life and the circuit is accurate.
Something unrelated I should add: You CAN NOT make a FAT16 SD card image for Proteus using WinImage software. It creates a FAT12 instead. I saw many tutorials where they said to use winimage, but it doesn't work and i thought there was something wrong with the code, but I just had to download a real FAT16 image.
