Snub
Newbie level 5
- Joined
- Feb 24, 2015
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 84
I want to reduce the heat generated in a circuit where the IRF3205 mosfet drives a flyback transformer with a pwm signal (fmax=50KHz) provided by the TL494 chip ,so optimal performances, Must I use a schootky diode (SBL3040PT VF=0.55V ) or a ultrafast one ( MUR820 VFmax= 0.97V trr=35nS) ?
p.s the circuits works perfectly,but I'd like to improve the efficiency..the irf3205 mosfet has inside a wheeling diode with a typical trr= 69nS and trr max=104nS VF=1.3V)
if I used the MUR820 diode,the internal diode will be bypassed,so less heat generated by the mosfet?
very thanks
very thanks
