Schematics of 3000watt converter
muhammad_kashif
Newbie level 3
aslamu-a-lukum
i need 12V DC [/color]to 220V AC 3000watt inverter circuits.
plz give me with small working circuits
Re: converter 3000watt
Look arround in this forum and u'll find morethan hundres of circuits with same interest and nature. Good luck
converter 3000watt
Where is 300A going to come from?
A car battery supplies hundreds of Amps for only a few seconds to start the car's engine. The battery will boil if it tries to feed 300A for more than 1 minute. If the engine is running then the car's alternator will burn out.
Most cheap Chinese inverters don't say if the output waveform is a square-wave, a modified sine-wave or a pure sine-wave.
muhammad_kashif !
What is your application !
I know that there is massive load shading in Pakistan so every one is after
UPS & Inverters .
If you want for ceiling fans ( because it is too much hot )
UPS is not suitable for ceiling fans.
You can use it for lighting & TVs .
For ceiling fans GENERATOR is most suitable.
