Actually i haf go through for the Application Notes for the PIC16C71. But there is only simple connection. If i follow the connection as the application notes, it is gonna work ?
I'm using PIC16C71 as 3 channel A/D converter for my project as to measured the input voltage then can display the measured voltage at the PC. I want to connect the PIC16C71 to MAX 232A then i use RS-232 to interface to my pc serial port.
My problem is if i use RA0, RA1 & RA2 as my analogue input, the how i gonna output the value after i digitalize it at the PIC PORTB (RB0-RB7) ? Am i need to use all the PORTB as my output ? I mesn how many output do i haf at the last ?
If it is like that, then how i gonna connect to the MAX232A as there are only 2 input for CMOS/TTL & i'm using 3 channel of the PIC.
Do i need to write any programme for the RS-232 to interface to the PC?
Thx ~ !
