Scenarios for MIMO correlated Channels
lastminuteproject
Aachen (Germany)
Hi everybody,
SHORT VERSION
I need a relation between standard scenarios and space-correlation factor of the transmission matrix.
LONG VERSION
I'm working in a MIMO channel generator which only need 3 inputs (easy to don't concern the time of the simulations):
- MIMO scheme (Tx and Rx antennas)
- SINR from the SISO communications (the actual simulator that we have is SISO only)
- Correlation factor desired for the channel
The code seems to work quite well, but now I need to associate the standard scenarios with certain correlation factor of the MIMO channel (in my case only correlation in space, not in time).
I was trying to generate some scenarios with the WINNER II model and then calculate the correlation, but it doesn't work.
Anyone know about it or has any idea to try?
Thank you in advance
