raviram80
Member level 3
Scan Sequence Question : Changing Measure PO
Hi All,
I have following question
Scan operation has the following steps according to Mentor Graphics Document.
The operating procedure of the scan circuitry is as follows:
1. Enable the scan operation to allow shifting (to initialize scan cells).
2. After loading the scan cells, hold the scan clocks off and then apply stimulus to the
primary inputs.
3. Measure the outputs.
4. Pulse the clock to capture new values into scan cells.
5. Enable the scan operation to unload and measure the captured values while
simultaneously loading in new values via the shifting procedure
My Question is
What will happen if we move the Step 3 "Measure the Outputs" after the Capture pulse?
Please explain?
Thanks.
Hi All,
primary inputs.
My Question is
Please explain?
Thanks.
