[General] Saving Data in to Controller
idontno
Newbie level 3
Newbie level 3
Dear Helper
I am working on my personal project and I need a help for it.
I want to attached a barcode scanner via USB Port in to my controller unit, at the moment it has ATmega8 controller, obviously controller will have limitation of memory to store the data but is it possible to store scanned barcode ?
let me make it simple. there is a scanner attached to controller unit via USB port of my controller unit, I want to save all scanned barcodes in to ATmega8
I understand that I might need some other controller to make this possible,
do I also need some extra memory chip in to my circuit so that I can have more space to store this data ? I wanted to manipulate this data on later stage.
any help will be much appreciated
Thank you very much.
Dear Helper
You first need to establish how many bytes of data your bar code reader produces for each read ? then how many readings / time frame you want to store them for ?
That will determine your storage needs, either eeprom chips or a sd card.
Being as you are using the Atmega chips the Arduino arena seems a good starting place.
https://www.circuitsathome.com/mcu/connecting-barcode-scanner-arduino-usb-host-shield
