[SOLVED] Save error on Pad Designer Allegro 16.3
AstridFraise
Newbie level 6
Hello
Well I have install on my computer the Allegro 16.3 and recently I installed PAD 9.3 and maybe that was a terrible mistake, because Capture from Allegro crash and the Pad Designer too.
So I fix the problem with Capture changing the variable "path" but now I find out that Pad Designer doesn't save the pads T_T and the only error is "Save error: -3000289"
Someones nows about this problem about PADS and Allegro in the same PC? and how to fixes?
Thanks for your time.
T_T
This is the solution:
Go to CONTROL PABEL-->SYSTEM-->ADVANCED-->ENVORIMENT VARIABLES->
And on SYSTEM VARIABLES add or change depends of your computer, this variables.
CDS_LIC_FILE C:\Cadence\LicenseManager\license.dat
CDS_LIC_ONLY 1
CDSROOT C:\Cadence\SPB_16.5
CHDL_LIB_INST_DIR %CDSROOT%
CONCEPT_INST_DIR %CDSROOT%
HOME C:\SPB_Data\
OA_PLUGIN_PATH %CDSROOT%\Share\oaPlugIns
For this last one only copy and paste the direction for Mentor graphics on the end
PATH C:\MentorGraphics\Allegro Export ODB++\nv\bin;C:\Program Files\TortoiseSVN\bin;%CDSROOT%\tools\pcb\bin;%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT%\tools\fet\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\tools\PSpice;%CDSROOT%\tools\PSpice\Library;%CDSROOT%\tools\Capture;%CDSROOT%\OpenAccess\bin\win32\opt;E:\Mentor\9.3PADS\SDD_HOME\common\win32\bin;E:\Mentor\9.3PADS\SDD_HOME\common\win32\lib;%MGC_HOME%/bin;%MGC_HOME%/lib;%MGC_HOMEBS%\bin;%MGC_HOMEBS%\lib;
Now I have Cadence 16.5 and PADS9.3 working without problems
Regards
