Saturn inductance calculator
arunmaran10
Junior Member level 2
Hi All,
I am using the saturn calculator for inductace. But due to formula restrictions i couldn't calculate indutctance for greater rhan 40 mills since W/H should be less than 3
But height(H- space between two layer) is around 8 mills which is constant.
So suggest some other tool or app or formula to calculate inductane of trace width.
Regards,
Arunmaran
Try Polar Instruments tool or let me know the exact value for below parameters so I calculate for you. By the way what is the board material?
W1,W2: 100mills,80.
H1:0.2mm(8mills).
H2:12mills.
T1:please tell for both 1ounce and 2ounce.
Er1,2:0.4(FR4 material).
Thanks in Advance.
Regards,
Arunmaran
Please see attached picture for trace inductance 80mil &100mil (1 & 2 Oz) using Polar. Hope it will help
Thanks a lot.
Regards,
Arunmaran
