Satellite mobile phone antenna design
Rydryn
Newbie level 5
Wroclaw Poland
Hi all.
I need to design an antenna for satellite mobile phone. This antenna must be used in car. It should be easy to build. I use IE3D software.
Do you know what type of antenna is the best solution? I thought about microstrip antenna(slot coupled).
This antenna should work at 1525 - 1660MHz. I think a good solution is antenna with circular polarization.
Do you have any experience in this type of antennas? I would be grateful for any suggestions.
Regards
Rydryn
mobilephone antenna design
For GPS , satellite communication are all for circular polarization
Slot antenna is the popular type for it due to easy feed method.
Maybe the helical antenna is also the other good type .
Because many satellite antenna use this type.
