shaku
Junior Member level 1
- Joined
- Jul 8, 2013
- Messages
- 17
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 127
Hi All,
I have a question on S5GC FDICT-ND diode. I have used this diode into my DC-DC Power Supply circuit at Input side.
Here is the connection: -
DC + to Fuse to Filter circuit to anode of this diode and cathode of this diode to DC-DC switcher and output.
DC- to Filter circuit to DC-DC switcher and output/ground.
Now question is: - This diode generates too much heat while I was testing power supply circuit at 19.5V input and at 2.5Amp load. This diode can handle upto 5Amp per specification. My question is, why this diode is generating too much heat?? (I have flare temperature gun and it measures 278F on the diode (not acceptable) and rest circuit shows around 90-100F). What is the alternative of this diode?? What else I can do to reduce heat??
I would like to know reason why is it generating this much heat??
Thank you,
Shaku
Thank you,
Shaku
