What does a S11 frequency response tells us?
This is my understanding. Pls advise if I am correct.
From what I understand, S11 is a measure of the reflection from an antenna. 0dB means that all the power is reflected, hence the matching is not good. -10dB means that 0.1 * incident power is reflected, meaning 0.9*power is accepted by the antenna. Coupled with the fact that most antenna designed are with low loss, the 0.9*power is radiated out. Hence, when we see a dip (V shape) cutting the -10dB level, we normally label the apex as the resonant frequency. However, we can also apply a matching network to the antenna to make sure it is conjugate-matched to 50ohms. If so, we can design antenna with any frequency we want?
