... to be a little bit more precise:
Using S11(f) expressions of a transmission line with characteristic impedance ZW and termination impedances ZT, we can see 20*log10( abs(S11(f))) having maxima and minima.
For a simple transmission line, the input reflection coefficient r_input is the reflection coefficient of the output impedance rT and the complex exp function
r_input=rT * exp(-2*gamma*length)
plotting this (20*log10(abs(rinput))) over freuency does not include maxima and minima.
The experiment prerequisites aren't completely clear. Perhaps you should clarify in which situation you observe |S11| maxima and minima.
If the transmission line impedance is equal to the S11 reference impedance, there's no ripple, S11 is just rotating around the origin and |S11| stays constant. But with different transmission line impedance, you get maxima and minima. You can visualize the problem using Smith chart.
Exactly. And when the line impedance is n* lambda/2, you get Zin=Zload. That's one case for ripple in S11: 50 Ohm load, 50 Ohm reference impedance, but the cable impedance is somewhat different.
