muni123
Member level 3
Hi all,
I am using Xilinx ISE on a remote server which is acessible through VPN n/w. When I run the shell Script from my machine, a pop up window of Xilinx ISE must be opened. But Its not happening here...
Iam getting message lke " You will not be able to run ise because ur machine does not have the required version of UNIX ". This message might be in the server script.
But I am using Windows XP machine and using ssh login to run Xilinx on that server. How can I install UNIX version to run Xilinx.
What can I do to open the Xilinx ISE on the Remote server.
Thanks In Advance....
Added after 2 hours 39 minutes:
Friends...
Now Iam able to open the applications by loggging on to the servers using VNC server.
Thanks...
Friends...
Thanks...
