i need to change the lib file with adding related pins to before the timing arks. I found that if i can include any special character at the end of pin description like with }# i can make the extraction easy. To include i tried :937s/$/#/g command in vi editor.
I want to run a unix script that can go to the line numbers of the file and work as above vi command and need to know how to write and implement vi commands from unix scripts.
