milkdrop
Junior Member level 1
did anyone tried to run somehow code from RAM on PIC?
i made it with motorola HC08 micrcontrollers - that have Von Neumann's architecture making easy to jump from code space to data space with loaded program, but PIC are Harward architecture based with separate data and code spaces.
my idea is to load a little piece of code from outside to RAM and let it run, then to return to original code in flash.
i don't need very fast running code and big amount of memory space.
one way to do this is to use ROMless PIC, but i don't want to use them.
other possibility is to write the code in free space in flash, with 18F devices it is easy, but the program flash memory (as well as other flash memories) have limited numbers of write cycles, so it is not acceptable for me.
is there any other solution i didn't mention?
