RS485 pic18f4550 not working
arafatronics
Newbie level 3
Newbie level 3
Hi
I'm Programming 2 pic18f4550 -Master and slave- for the RS485 communication using MAX485
when i tried it in protus it worked very nice but in hardware there is nothing work at all
the slave code is :
char dat[9]; // buffer for receving/sending messages
char i,j;
sbit rs485_rxtx_pin at RC2_bit; // set transcieve pin
sbit rs485_rxtx_pin_direction at TRISC2_bit; // set transcieve pin direction
// Interrupt routine
void interrupt() {
RS485Slave_Receive(dat);
void main() {
ADCON1 |= 0x0F; // Configure all ports with analog function as digital
CMCON |= 7; // Disable comparators
PORTB = 0;
PORTD = 0;
TRISB = 0;
TRISC6_bit = 0;
TRISC7_bit = 1;
TRISC1_bit = 0;
TRISD = 0;
UART1_Init(9600); // initialize UART1 module
Delay_ms(100);
RS485Slave_Init(160); // Intialize MCU as slave, address 160
dat[4] = 0; // ensure that message received flag is 0
dat[5] = 0; // ensure that message received flag is 0
dat[6] = 0; // ensure that error flag is 0
RCIE_bit = 1; // enable interrupt on UART1 receive
TXIE_bit = 0; // disable interrupt on UART1 transmit
PEIE_bit = 1; // enable peripheral interrupts
GIE_bit = 1; // enable all interrupts
while (1) {
if(dat[0] == 0x01){
RD3_bit ^= 1;
Delay_ms(1000);
dat[0] = 0;
if(dat[0] == 0x02){
RD2_bit ^= 1;
Delay_ms(1000);
dat[0] = 0;
if(!RC1_bit){
Delay_ms(50);
if(!RC1_bit){
RD3_bit ^= 1;
I suppose that the problem is in the slave code
i tried to connect the A and B to VCC and GND by resistors but no action happens
could please help me
thanks a lot
Can you give the function definition too:
Also try to make TRISC6_bit = 1;
I had declared the problem
the data is sent and received but the data received is not the desired data sent actually
then the receiver cannot recognize it
so how to overcome that problem?
thanks a lot
Normally max 485 in receive mode DE/RE = 0;
When you want to transmit the data you will make max485 into transmit mode know. that is DE/RE = 1;
After that put a delay of about 15ms then you start transmission.
After finishing the data transmission before changing the mode back to receive mode DE/RE = 0. put a delay of 15ms. then make DE/RE = 0.
It may help;
See if you have a code like this...
TXREG = VALUE;
DE/RE = 0;
Here you are immediately switching to receive mode after written into TXREG register. So before the data is completely shift out from TSR register you changing back to receive mode and hence the receiver device may receive wrong data. Even some times the receiver device gets no data as it may not receive stop bit.
So i mentioned to put delay before changing the mode. But the value of 15ms is depends on baud rate. How larger the baud you can reduce this delay. I just told this value for baud of even 1200.
There is another way to do this also. You may also poll the TSR empty pin and change the rs485 mode once the register is empty. Since no interrupt logic available for this bit i simply used delay.
checking the BF flag will do this ..
if Transmitting after loading val to TXREG .. while(!BF) ; if recieving after eneabling RCEN .. while(BF); .
