dara65
Newbie level 1
Hi every body
I'm supposed to simulate a rotary field ferrite phase shifter in HFSS. in the phase shifter, the transverse magnetic bias field is rotating in continually around the ferrite material. the rotation of the bias field causes changing the polarization of the output wave compared to the input one and . for example when the bias is in Z direction the phase shifter should apply a 180deg phase shift on the wave and when the bias is rotated 90deg to the Y direction, the phase shifte should be zero.
i'm not sure how to simulate it correctly:
1- how to monitor the output waves to see if the 180deg phase shift has been applied?
2- how to compare the polarization of input and output waves?
3- how to apply rotary field phase shifter?
4- If any body has done such a simulation that would help me, i would appreciate his/her help.
