i compile a rom and a ram using RapidCompiler.After P&R,i stream out the gds ,then stream it in the Caliber to view the layout. i find all the Standard Cells is OK,all the pins connected but
there isn't any metal net in the rom and ram,i can only see the nwell,pdif,ndif and poly in them.why?Are the metals in the rom/ram routed in the course of
memory compile or in the course of astro routing?
mapping files are ok? when you stream in or stream out,
or the caliber techfile and the rapidcompiler techfile are the same, especiall the metal layer number ?
