nagsaver
Junior Member level 1
I am making a robot controlled by sony TV remote whose output IR is detected by TSOP1738....I have programmed the micro(ATMEGA8L) using appropriate control codes of the tv remote.....the thing is that the output from my tsop is nearly 4v without ir but when any button is pressed it only reduces to closely above 3v which is still logic high for my atmega whose vcc is 5v.....what may be the problem...?????the connections of TSOP are as follows
1st pin--->>>Ground
2nd pin--->>>+5v via 100 ohm resistor
4.7 microf capacitor between 1st pin and 2nd pin
what may be the problem????Also any further suggestions for my project are certainly welcome....
1st pin--->>>Ground
