Roadside detection in opencv or matlab
ANS HAFEEZ
Full Member level 1
LAHORE,PAKISTAN
SALAM..
i have to detect road side i m using RASPBERRY PI MEDEL B+ + PI CAM....
First i have to detect road side then find the center of road on which i have to drive car autonomously..
please suggest any best algorithm or links which can help me
Any Help ...
I Want output like ths
In some ways this resembles a line-following robot. The logic is based on light/dark detection.
Two sensors are side by side. If one sensor detects vegetation (which looks purple in your photograph), then turn the wheels to avoid it. The robot will stay centered on the road.
i hv apllied CANNY edge detection but it create to much noise
then i also apply smoothing algos but found no solution
There is not a standard procedure for determine the image enhancement sequence suitable to different applications. In some cases it is necessary to dilate the image before apply edge detection, on other after. For distinct image patterns may be required adopt different approaches and you might perform several tests by a combination of various functions and deduce it by yourself.
Additionally, you could also employ several other cameras to check the performance of each one. For instance I had used a cheap one that yielded the best quality on image, if compared to several reputable others.
