Jagajack
Newbie level 6
- Joined
- Mar 12, 2013
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Chennai, India
- Activity points
- 1,365
Hi all,
I am designing a H-Bridge inverter for induction furnace application. My DC bus voltage is 400 V and current is 15 A.
To start with I used 12 V supply to test my H-Bridge inverter connected to load resistor of 10 Ohm.
I used IXFH26N50 from IXYS semiconductor for H-Bridge and the MOSFETS are driven by two IR2110 drivers.
But during turn-on of the MOSFETS, I could see excessive ringing at both the output terminals of the H-Bridge with respect to ground and also on the MOSFET gates.
I have used shielded twisted wires to connect driver terminals to MOSFET to reduce the wire inductances and 1000µF capacitor on the DC bus, but no appreciable reduction in ringing noise amplitude.
In many papers and application notes it is mentioned that, this ringing is due to gate to drain capacitance and can be suppressed with the use of ferrite beads near gate terminal.
But I have not tried with ferrite beads, will ferrite beads suppress this ringing?
Will changing the MOSFET be a solution? If so help me to choose a MOSFET that could have lesser switching noise and suitable for induction heating application.
Please help.
Please help.
