Artlav
Full Member level 2
Hello.
I'm making a boost converter to power HID lamps from lead-acid/LiPo batteries.
The schematic is quite straightforward:
However, there is quite a lot of ringing on the output.
Converter frequency is 100KHz.
On each turn-on and turn-off of the MOSFET there is a high frequency ring.
+-2V ringing, at 20V, 2A total output into a resistor load, ~20% duty cycle:
Zoom in (1..5 us/cell, same 2V/cell), apparently out of baud for the scope or something:
At higher power it gets worse.
What could be causing it?
Can it be what makes the lamp (150W xenon short arc) flicker like TV static?
