Ring counter implementation in vhdl
poornimayn
I'm a newbie in VHDL. I'm trying to implement 4 bit Ring counter using DFF.
I'm using one preset DFF and other FF has a reset for initialzing purpose.
I could able to preset/reset the value but not able to shift the value in the Flip flop ring after reset/Preset.
I'm using Xlinx ISE 14.3 . I'm facing problem while simulating the counter!!..
Below is the code for Preset DFF and Reset DFF and also for Ring counter.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
----PRESET DFF-------
entity DFFPreset is
    Port ( preset : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           d : in  STD_LOGIC;
           q : out  STD_LOGIC);
end DFFPreset;
architecture Behavioral of DFFPreset is
begin
process(clk,preset)
begin
if preset ='1' then
q<='1';
elsif clk'event and clk ='1' then
q<=d;
end if;
end process;
end Behavioral;
---------RESET DFF---------
entity DFF is
    Port ( reset : in STD_LOGIC;
            clk : in  STD_LOGIC;
           D : in  STD_LOGIC;
           Q : out  STD_LOGIC);
end DFF;
architecture Behavioral of DFF is
begin
process(clk,reset)
begin
if reset='1' then
Q <= '0';    -- clear register
elsif (clk'event and clk='1') then
Q<=D; --positive edge of clock is used
end if;
end process;
end Behavioral;
-------------------4 bit Ring COunter-----------------
entity ringcounter is
            clk : in  STD_LOGIC;
           count : out  STD_LOGIC_VECTOR (3 downto 0));
end ringcounter;
architecture Behavioral of ringcounter is
signal q0,q1,q2 : STD_LOGIC := '0'; ---initialising the signals
--signal temp :STD_LOGIC := '1'; --not using it as of now.
signal q3 :STD_LOGIC := '1';
component DFF is
            clk : in  STD_LOGIC;
            D : in  STD_LOGIC;
            Q : out  STD_LOGIC);
end component;
component DFFPreset is
           clk : in  STD_LOGIC;
           d : in  STD_LOGIC;
           q : out  STD_LOGIC);
end component;
begin
DFFPreset1 : DFFPreset port map(preset,clk,q3,q0);
DFF2         : DFF port map(reset,clk,q0,q1);
DFF3         : DFF port map(reset,clk,q1,q2);
DFF4         : DFF port map(reset,clk,q2,q3);
count <= q3&q2&q1&q0;
end Behavioral;
you need to add below lines , since this is one file and you have used 3 entity , you need to declare both lines 3 times , just before the entity .... once you done ..your code is good to go ..
library ieee;
use ieee.std_logic_1164.all;
Rahul
Let me know if you encounter any other issue :)
I have added the lines you have mentioned in my code. The DFF files are in different files in the same workspace, I have just instantiated then by declaring component of DFF.
I guess I have to make it further clear to make you understand my problem.
simulate the code using simulator and
Step 1> Force reset/preset values of the flip flop.
Step 2>In addition to the above step I force the clock also.
Step3>Now I click on run I could see the initialised values on the Flip flop output.
Now My intention is to circulate these set values in the RingCounter.
How do I do it?
Does it require modification in the code?
Or Am I going wrong in the way I force the input and make the observation?
