Nov 3, 2019 #1 B big_fudge98 Member level 2 Joined Mar 31, 2019 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 445 Hi all, I have designed a subtheshold opamp with UGB = 20 kHz. I calculated the RHP zero to be at 250 kHz. Should I go for RHP zero cancellation by adding a resistance before the compensation capacitor? In general, when do we go for RHP cancellation? Thanks.
Nov 3, 2019 #2 B big_fudge98 Member level 2 Joined Mar 31, 2019 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 445 So if the phase margin is greater than 60 without RHP zero cancellation, I am safe, correct?
Nov 3, 2019 #3 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,414 Helped 14,749 Reputation 29,780 Reaction score 14,097 Trophy points 1,393 Location Bochum, Germany Activity points 298,073 If required for stability of the intended feedback circuit. - - - Updated - - - Sufficient phase margin and only single crossing of the 0 dB loop gain line.
