RFID Tag ID Recognition
imranahmed
Advanced Member level 3
Karachi,Pakistan
Please let me know that I build a circuit for displaying RFID tag ID.
The ID is written on card is 0001712436 026,08500.
The circuit is 89c52 uC based,
The card ID is received on LCD(20x2) like, |||0001712436||
The 3 lines on start of code and 2 lines on end of code is displaying.
How to fix this problem?
Please find the attachment, How Hyper terminal display the code please see.
Maybe some additional ascii data is appended while transmitting the tag. Just use something like this
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
char buff1[20], buff2[20];
//buff1[] is used in ISR where RFID data is dumped to it.
while(1) {
      while(buff1[i]) {
              if((buff1[i] >= '0') && (buff1[i] <= '9'))buff2[j++] = buff1[i++];
      buff2[j] = '\0';
      lcdPrint(buff2);
Zip and post your complete project files. I will see if there is any better way to modify the code. Does any of the RFID tag contains characters A to Z or a to z ?
//Program to interface RFID with 8051 microcontroller (AT89C51) #include<reg51.h>
unsigned int data_out,command=0x80,temp;
sfr lcd_data_pin=0xA0; //P2 port
sbit rs=P1^0;        //Register select
sbit rw=P1^1;        //Read/Write
sbit en=P1^2;        //Enable pin
unsigned char card_id[12];
void delay(unsigned int count)    //Function to provide delay
    int i,j;
     for(i=0;i<count;i++)
     for(j=0;j<1275;j++);
void lcd_command(unsigned char comm)   //Lcd command funtion
     lcd_data_pin=comm;
     en=1;
     rs=0;
     rw=0;
     delay(1);
     en=0;
void lcd_data(unsigned char disp)  //Lcd data function
     lcd_data_pin=disp;
     en=1;
     rs=1;
     rw=0;
     delay(1);
     en=0;
lcd_string(unsigned char *disp)     //Function to send string
     int x;
     for(x=0;disp[x]!=0;x++)
         lcd_data(disp[x]);
void lcd_ini()                  //Function to initialize the LCD
    lcd_command(0x38);
    delay(5);
    lcd_command(0x0F);
    delay(5);
    lcd_command(0x80);
    delay(5);
void recieve()     //Function to recieve data serialy from RS232
    unsigned char k;
     for(k=0;k<12;k++)
         while(RI==0);
          card_id[k]=SBUF;
          RI=0;
void main()
    int l;
    TMOD=0x20;            //Enable Timer 1
    TH1=0XFD;
    SCON=0x50;
    TR1=1;                // Triggering Timer 1
    lcd_ini();
    lcd_command(0x81);        //Place cursor to second position of first line
    lcd_string("UNIQUE CARD ID:");
    delay(200);
    while(1)
         recieve();
         lcd_command(0xC1);        //Place cursor to second position of second line
         for(l=0;l<12;l++)
              lcd_data(card_id[l]);
Please see the code.
The ID on card is only 0001712436 026,08500
Is it Keil uVision Code ? If yes, Zip and post the complete Keil project.
Try attached project. RFID baudrate is 9600 bps.
  • RFID Reader.rar
Thank you for given project.
I need not only display Tag ID but I am comparing tag ID with tag ID is saved in code.
If ID match the door should be open.
But I am build code for checking that it can receive proper ID or not and not for opening door.
Code is below,
// Atmel AT89C52 @ 11.0592MHz
#include<reg52.h>
#include<string.h>
#include<stdio.h>
sbit rs=P3^1;          //Register select
sbit en=P3^3;          //Enable pin
unsigned char current_byte=0,flag=0;
unsigned char val1=1;
code const char Student1[]="200017124353";
     int i,j;
     lcd_data_pin=comm;
     en=1;
     rs=0;
     delay(1);
     en=0;
     lcd_data_pin=disp;
     en=1;
     rs=1;
     delay(1);
     en=0;
void lcd_string(unsigned char *disp)     //Function to send string
     int x;
     for(x=0;disp[x]!='\0';x++)
         lcd_data(disp[x]);
void lcd_init()                       //Function to initialize the LCD
    lcd_command(0x38);
    delay(5);
    lcd_command(0x0F);
    delay(5);
    lcd_command(0x80);
    delay(5);
void display()                     // Function to display the unique id
    unsigned char count;
    for(count=0;count<15;count++)
          lcd_data(card_id[count]);
    current_byte=0;
void recieve() interrupt 4           //  Function to recieve data serialy from RS232
     card_id[current_byte]=SBUF;
     RI=0;                            // Reset the serial interrupt after recieving the byte
     current_byte++;
     card_id[current_byte]='\0';
void RFID_routine()
      while(current_byte!=13);
	    val1=strcmp(Student1,card_id);
			if(val1 == 0)
      current_byte=0;
      lcd_command(0x01);        //Clear LCD
      lcd_string("Condition true");
			else
			current_byte=0;
	    lcd_command(0xC1);        //Place cursor to second position of first line
      lcd_string("Condition false");
void main()
    TH1 =0xFD;
    SCON=0x50;
    TR1 =1;                // Triggering Timer 1
	  EA  =1;
    ES  =1;
    lcd_init();
    lcd_string("UNIQUE~CARD~ID:");
	  delay(10);
    while(1)
			RFID_routine();
Did you see my code ? In that you only have to add
I have attached my project which is working.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
const char tag[] = "200017124353";
while(1) {
         if(index >= 20) {
                 parseRFID(card_id, text);
                 if(strcmp(tag, text) == 0) {
                         LCD_Out(2,1,"Access Granted...");
                 else {
                      LCD_Out(2,1,"Access Denied...");
                 index = 0;
                 memset(card_id, '0', 30);
                 memset(text, '0', 25);
  • RFID Reader rev1.rar
Dear milan,
Thank you for your co-operation.
I am working on your given project and I will reply you as soon as possible.
Regards,
Imran
