aqibpervaiz
Newbie level 1
- Joined
- Dec 15, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 18
hi i m making rfid base security system in which when u bring card near relay which operate and lock will be open.problem is it does not goes on the true statement it always goes on else statement what ever card i put near to it. i m share u my code plz help me.thanks in advance.
#include<reg51.h>
#include<string.h>
sbit relay=P2^0;
sbit led=P2^1;
sbit pled=P2^2;
unsigned char k=0;
char temp=1;
void delay(unsigned int itime);
void get_code();
unsigned char check();
unsigned char aqib[13]={'¿','Y','Ù','ö','Ö','‘','‘','›','‘','y','w','y','ù'};
unsigned char reid[13];
void main (){
//aqib[0]="¿"
//aqib[1]="Y"
//aqib[2]="Ù"
//aqib[3]="ö"
//aqib[4]="Ö"
//aqib[5]="‘"
//aqib[6]="‘"
//aqib[7]="›"
//aqib[8]="‘"
//aqib[9]= "y"
//aqib[10]= "w"
//aqib[11]= "y"
//aqib[12]= "ù"
//aqib[0]=10111111;
//aqib[1]=01011001;
//aqib[2]=11011001;
//aqib[3]=11110110;
//aqib[4]=11010110;
//aqib[5]=10010001;
//aqib[6]=10010001;
//aqib[7]=10011011;
//aqib[8]=10010001;
//aqib[9]=01111001;
//aqib[10]=01110111;
//aqib[11]=01111001;
//aqib[12]=11111001;
relay=0;
led =0;
pled=0;
SCON=0x50;
TMOD=0x20;
TH1=-3;
TR1=1;
while (1){
pled=1;
get_code();
//temp = strcmp(aqib,reid);
temp=check;
if (temp==13) {
relay=1;
delay(500);
relay=0;
else
{ unsigned char i;
for (i=0;i<10;i++){
led=1;
delay(100);
led=0;
void get_code(){
for (k=0;k<13;k++)
while(RI==0);
reid[k]=(char)SBUF;
RI=0;}
unsigned char check(){
//strcmp(reid,aqib)
unsigned char temp=0,i=0;
for (i=0;i<12;i++){
if ((reid)=(aqib)){
temp=temp+1;
return temp;
unsigned int i,j;
for (i=0;i<itime;i++)
for (j=0;j<111;j++);
#include<reg51.h>
#include<string.h>
sbit relay=P2^0;
sbit led=P2^1;
sbit pled=P2^2;
unsigned char k=0;
char temp=1;
void get_code();
void main (){
//aqib[0]="¿"
//aqib[1]="Y"
//aqib[2]="Ù"
//aqib[3]="ö"
//aqib[4]="Ö"
//aqib[5]="‘"
//aqib[6]="‘"
//aqib[7]="›"
//aqib[8]="‘"
//aqib[9]= "y"
//aqib[10]= "w"
//aqib[11]= "y"
//aqib[12]= "ù"
//aqib[0]=10111111;
//aqib[1]=01011001;
//aqib[2]=11011001;
//aqib[3]=11110110;
//aqib[4]=11010110;
//aqib[5]=10010001;
//aqib[6]=10010001;
//aqib[7]=10011011;
//aqib[8]=10010001;
//aqib[9]=01111001;
relay=0;
led =0;
pled=0;
SCON=0x50;
TMOD=0x20;
TH1=-3;
TR1=1;
while (1){
pled=1;
get_code();
temp=check;
if (temp==13) {
relay=1;
delay(500);
relay=0;
else
{ unsigned char i;
for (i=0;i<10;i++){
led=1;
delay(100);
led=0;
void get_code(){
for (k=0;k<13;k++)
while(RI==0);
reid[k]=(char)SBUF;
RI=0;}
//strcmp(reid,aqib)
for (i=0;i<12;i++){
if ((reid)=(aqib)){
temp=temp+1;
return temp;
unsigned int i,j;
