Hello everybody,
Please i need your help in a project i'm working on, and here is the description of the project:
it's a transceiver module "Transmitter& Receiver", the transmitter to be installed in a key-chain like the car remote alarm one, with 4 buttons, to send four different signals to a Receiver which is the hard thing to be made in a very compact size PCB "3cm*1cm", to be installed in a bracelet in the hand of a child, with built in motor to make vibration when the signal is sent by the transmitter, so i need both the transmitter and the receiver to be included in a surface mount circuits.
so what the idea behind that project?, to do transmitter send four different signals to four receivers?, and how to do it?, would zigbee be a low cost way to use for the design?, or there is another way which is simple and lower cost than zigbee?, just need your help as i am not familiar with Communication engineering, but with some search and goggling i see that i can do the project, also with your help, so will appreciate your help a lot, as i'm in so much need to execute that project.
Thanks in advance.
