Hello All
I have designed a power amplifier at L -band in three individual stages.
I fabricated it and test individual also.
but after cascading , i did not get the optimum power. so there is definately impedence mismatch issue.
hance, the only option is that, i have to measure the impedence (with VNA) at output (S22) of stage "1" and input impedence (S11) of stage "2", and then match them to each other using impedence transformer circuit in between them.
As its high power amplifier (CW mode ), and output power of the satge "1" is 45 dBm and to next stage (stage "2") is 250W (54 dBm) power amplifier device which to be match.
As the VNA is very sensitive device i am not able to measure the Impedence .
if i connect the Atenuater in between , VNA directly show the port impedence of attenuator (standart 50 Ω)
Kindly help me in this issue.
How i can measure the impedece of high power amplifier outport using VNA.
