RF filter? Problems with CMOS at 868MHz
zahrein
Full Member level 2
RF filter?
I have been asked to design a band pass filter at 868MHZ using CMOS technology. I have found out that, it is difficult to deisgn at that frequency. The thing is i do not have any prove that can support my facts that it could not work at that frequency.
From my research, my Q factor is 10000. HOpe u all can give me some information so that i can answer to my supervisors.
RF filter?
the key element for designing BPF at high freq is to use active inductor...
Re: RF filter?
I am still in doubt but will this pattern of filter frequency response will be repeating itself at corner frequency n*868Mhz where n is n=1,2,3,... by using an active inductor?
I am not sure for CMOS I never designed in CMOS one. I am eager to learn it.
thank you
zanove
Re: RF filter?
CMOS can be made to be both inductor and capacitor. I saw it somewhere. Then you can use those elements to built a filter.
Re: RF filter?
Where you intend to use this CMOS band pass and power level through it???
XTASA
RF filter?
im design it for RFID application.. Is that answer ur question ?
Re: RF filter?
Inductors and capacitors in CMOS can be used to construct a filter with a Q of the order of 10 (maybe a little more) - this is mainly down to the Si substrate and cannot be overcome
If I understand you correctly and you require a filter with a Q of 10,000 then CMOS is not the way to go - you should try SAW technology maybe
jl
Re: RF filter?
There are many research papers about RF BPF published on various IEEE transactions. They usually handle 1 to 5 GHz RF signal on CMOS. However, the performance is not good enough to replace SAW in cell phone application. For you RFID application, I just don't understand why you need so high Q value for the filters. If the specification of your RFID is not stringent (such as dynamic range, power dissaption, noise figure), it's possible to implement on CMOS.
RF filter?
I ve known that i cant design a band pass filter using CMOS with the Q point almost 10^5.
What are the reasons that i cant design with CMOS with a high Q, i need to know the reasons as im still trying to findout the reasons. Is it impossible? WHy?
Re: RF filter?
The reason is simply due to the resistivity of Si substrate - this means that very high Q's cannot be achieved
SAW filters are normally produced on ceramic substrates enabling high Q's
RF filter?
the point is that inductor, do u try it??
