RF design Schematic related questions and comments
Rujul Desai
Junior Member level 2
Ahmedabad
hi,
I am designing smart sensor with i2c, UART and SPI interface and current & voltage measurement.
so which extra circuit is add for current and voltage measurement.
i am using ADC interface for current and voltage measurement.
i am using Load cell one of sensor..so how can it interface with microcontroller?
kanni1303
Full Member level 3
Full Member level 3
Chennai, Tamil Nadu, India
For current you can use current transformer and to detect the value of current, with help of OP-AMP or HALL sensor connected to ADC
For Voltage you can use potential transformer (which reduces your actual voltage in 1:N ratio, this can used for measuring large voltage values) and for detecting the exact voltage, with OP-AMP, comparator(ADC).
Simply after transformer the voltage can be sensed with ADC, but the actual value should not exceed the reference voltage
