Reverse polarity protection with FET is somewhat blighted by CDG capacitance
T
treez
It is necessary to provide reverse polarity protection for a 24W Buckboost LED driver with Vin = 8 to 136VDC. (when vin <18v, then power can be reduced to 2W).
I find that the diode D3 is needed to mitigate the current that comes through the drain_gate capacitance of the reverse polarity fet at supply-ON time. –Especially when Vin is negatively greater than -100V.
The simulator may be over-exaggerating the D-G capacitance of the FET……do you know how I can inspect how much D-G capacitance is in this FET in the LTspice simulator? (and how the simulator changes this capacitance with VDG?)
LTspice sim and pdf schem attached.
  • Reverse polarity protection.pdf
  • Reverse polarity protection.txt
Review the LTspice help for MOSFET VDMOS model. Together with the Vgd model parameters, you can calculate th assumed capacitance and compare with datasheet values.
I believe, you can easier compensate Cgd by a capacitor in parallel with gate source, e.g. some 10 nF.
A problematic point is exposing the drain terminal without overvoltage protection, e.g. a TVD diode. Vds,max is exceeded in your simulation circuit due to "line inductance" oscillations.
Reactions: treez
    T
