I have dc motor driver board and i want to do something like it. there are couple of things that i amn't sure of it in this board. it contains IR2184, NE555 , AP 34063 and other passive components(c, R,L).
I want to know what is the rule of AP 34063 , Is it dc/dc converter or voltage inverter what is the best suitable for IR2184 driver. the board use push button for manual control also
attached manual
for all the devices there are dedicated datasheets.
A simple google search on "AP34063" ...gives at first result the datasheet.
Read through them.
It´s faster and more straight forward if you read them... instead we read them and post you the informations...
And we don´t know what exactely you are looking for.
I have already read it before writing this post so i said that it's used as dc-dc converter or voltage inverter. i want to understand it's operation in this board which isn't written in datasheet. I ask for your experience here with this kind of h bridge drivers. I checked some lines of the board connections. I found that the generated ramp from NE555 is going to the comparator in the AP 34063. so i think its output is PWM. the question is which leg in the IR2184 would the AP 34063 give it its output?
When I looked at the block diagrams from pages 2 thru 4, it was deja vu.........where have I seen this?
Now I remember, it is a circuit I used long time ago, from Motorola Semiconductor, now OnSemi.
Looking for it at OnSemi's web page, I found the datasheet, which contains far more information, including crucial design equations for all three topologies:
