Decesicum
Member level 2
Hello,
I am trying to simulate a TEM cell in CST, to compare the simulated s11 to the measured one. On the measured curve I see some resonances (the expected ones for TE10 mode but also two other frequencies which I do not know where they come from) In CST no resonance at all, regardless on how many frequency samples I used; at first I thought I miss them when using a larger frequency step; this is what happened when I did that for the VNA. I use discreet ports as feed and load. Any idea why no resonances seem to occur in the simulated model?
Thanks!
Thanks!
