Resistor wattage in LAB PSU
neazoi
Advanced Member level 6
Greece
In this LAB PSU I have designed the 0.33 Ohms resistor, how many watts must it be?
Also, can I use another resistor value, or no resistor at all, and what effects will it have?
W=(I^2)R so it needs to be rated at 0.33 times the maximum load current squared.
The resistor is there to create a voltage drop at the 'set' pin as load current flows so it adjusts the voltage to maintain a constant current.
I would anticipate some drift problems using opto-couplers like that, as everything is ground referenced you could directly couple the voltages from the potentiometers to the ICs.
There should be a ground on the regulator IC!
Brian.
Reactions: neazoi
    neazoi
Brian.
So the the resistor must be 0.33*3.3=1.089 Watts for 3.3A max load?
I noticed the drift as well and I replaced the LDRs with pots like shown in the datasheet.
That seems about right. I would use a 5W rated resistor so it doesn't get as hot, any change in value will change the voltage sensed across it.
Brian.
power requires the current be squared P =I^2* R
or 0.33 ohm * (3.3 A) ^2 = 3.6 W
a 5 W resistor should be ok
Sorry, I missed that the current hadn't been squared in post #4 but as wwfeldman points out, 5W is adequate anyway. It is the temperature coefficient that really matters as it changes the current limit.
Brian.
