Register Log in
[SOLVED] Resistor marked value vs. actual outside tolerance?
RobAinscough
Junior Member level 3
I purchased a variety pack of resistors 1/4w 1% tolerance ranging from 0\[\Omega\] to 10M\[\Omega\]. I haven't tested every single resistor, but I did test many in the lower end from 0.5 to 10\[\Omega\] and most of them were not as marked and outside tolerance ... for example:
0.5 marked was 0.8 actual resistance
1.0 marked was 1.3 actual resistance
outside the 1% tolerance ... once I got above 10\[\Omega\] marked they started to fall within tolerance.
Is this common? Just a bad resistor manufacturer or something else?
Cheers, Rob.
andre_teprom
Super Moderator
Staff member
Brazil
Note that the same difference of above 0.3Ω happens in both, don't seem it could be due to the resistance of the multimeter cable?
c_mitra
Advanced Member level 5
Resistances smaller than 1 ohm may be tricky to measure accurately with a conventional multimeter. You need to use a 4-point probe.
But I am surprised that resistors in the range 1-10 are also not showing accurately. Did you check with the multimeter specs?
RobAinscough
Thanks for the responses, took me a while to check with my Oscilloscope, but it does indeed seem to be my DMM has about 0.3\[\Omega\] in cables and/or internal ... Mystery solved.
Cheers, Rob.
Toggle Sidebar
