A.Rashad
Member level 4
My Microcontroller's (LPC2148) reset pin remains high continously.
when I press reset switch the voltage on reset pin goes to 0 ie. shorting to ground but when i releases the reset switch , it comes 2.15 volts?
please suggest
SCHEMATIC ATTACHED...
Note : In schematic's reset circuit the switch's second(lower point is connected to the ground), but NET name is missing(sorry for not mentioning in schematic)
What voltage should I get on Reset pin as per this schematic? (as per my view it should be 3.3 volt , but when switch is pressed it should be 0 v means shorted to ground).
but I am getting 2.15 instead of 3.3 , thats why my lpc flash magic is giving me auto baud failure error...
please suggest
