require help in identifying right zigbee modules
kirtan
Junior Member level 2
Dear Sir,
As per our communication before kindly clarify following
Requirement: Create 8051/ATMEGA32 based wireless network using Zigbee module for Home Automation. The set-up requires both both point-to-point communication as well as multinode communication may be in mesh network form.
I have identified following modules related to zigbee.
1. XBEE 2mWire antenna -series 2 (Mesh) --- to act as zigbee wireless node (we require 3-5 units)
2. XBEE explorer regulated - to mount xbee module and to interface it with microcontroller (quantity required equal to number of boards purchased at Sr. No. 1)
3.XBEE explorer USB -to configure XBEE (as this is used for configuration purpose only, purchase of 1 such board will be sufficient)
Kindly let me know if the above considerations are ok or requires some changes.
regards
