Mar 30, 2004 #1 E elektrom Full Member level 2 Joined Jul 2, 2001 Messages 127 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 965 Can you give me an example?
Mar 31, 2004 #2 W wufengbo Junior Member level 3 Joined Sep 25, 2003 Messages 31 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 265 I think ModelSim don't support systemverilog fully.
Apr 1, 2004 #3 E elektrom Full Member level 2 Joined Jul 2, 2001 Messages 127 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 965 I saw from its datasheet that systemverilog 3.0 is supported, not 3.1 which is use for making test bench. Is it correct?
May 6, 2005 #4 N nagraj Member level 2 Joined Feb 17, 2004 Messages 51 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 392 elektrom said: I saw from its datasheet that systemverilog 3.0 is supported, not 3.1 which is use for making test bench. Is it correct? Click to expand... Yes most of systemverilog 3.1 are used for verification
May 7, 2005 #5 A Arnold Member level 1 Joined Dec 4, 2004 Messages 32 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 262 you need to wait modelsim 6.1, I think
Jun 8, 2005 #6 K Kulprashant Member level 3 Joined Mar 28, 2005 Messages 59 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,288 Activity points 1,813 hi, i think modelsim 6.0 will support systemverilog.please try to verify the dataheet with regards, kul.
Jun 8, 2005 #7 N nand_gates Advanced Member level 3 Joined Jul 19, 2004 Messages 899 Helped 175 Reputation 350 Reaction score 53 Trophy points 1,308 Activity points 7,037 Yes modelsim 6.0 supports SystemVerilog! you can check running following examples... **broken link removed**
