REQ: Planar inverted-F Antenna Design
Rayengine
Full Member level 5
Hong Kong
Hi all,
We are going to use 1.8GHz and 2.4GHz Planar inverted-F antenna for design. Any one has experience on the simulation on this type of antenna.
What is the major difference between planar and non-planar inverted antenna.
Best Rgs
Rayengine
eirp
Advanced Member level 1
Phase center
Hi, Rayengine!
My colleague has built two of such antennas (unfortunately non-planar), for 900 and 1800MHz (used as detector of mobile phones in a jail!).
He successfuly designed it in IE3D full-wave MoM simulator. I'll ask him for details if you want.
Regards,
Eirp
Rayengine
Full Member level 5
Hong Kong
Thanks for help, please sent to me! My email: ray_wmwong@hotmail.com.
Moreover, as I heard from some antenna design, the planar inverted-F has a broaden bandwidth, so how can we control the planar area and where we place the feeding point because it is not so single like a L-antenna? It is now three-dimensional structure.
Thanks in advance
Hishamsaleh
Full Member level 1
check
Antenna theory - analysis and design
constantine A. Balanis
this book have extremly information that u may need.
hope to help
yingyang
Full Member level 2
antenna
You may like to check the book broadband compact antenna or the paper by BL Ooi on broadband stack antenna which has far superior performance with inverted F-antenna.
jallem
The main differences are:
1) Easy of construction, the PIFA is easier
2) Influence of ground planes around it, the PIFA is more susceptible to it,
specially for impedance.
3) Bandwidth, the non-planar has greater bandwidth.
4) PIFA is easier to match, since you can have a CPW transmission line
and use L/C network for matching
