REQ: PIC16F84 A/V/mAh meter for battery charger?
Spirit
Newbie level 5
Newbie level 5
mah meter
I built switching inteligent battery charger with MAX712 with discharging unit, and now I want to add digital V meter (15Vdc max), A meter (3A max) and I want to measure battery capacity while is connected to discharging circuit.
Charge-discharge is automatic with LED signalisation so I can get control signal from 3 LEDs (charge, discharge, finish)
I want to do this with PIC16F84 and 16x2 LCD.
Does anybady know how to do this or have some project shematic and hex?
phoenixdk
Junior Member level 1
pic16f battery charger
what are you charging li-ion/polymer ??....
Spirit
Newbie level 5
Newbie level 5
battery charger circuit+pic16f
I charge Ni-MH with modified factory switcher schematic and works great. At 2.5A everything is cold.
Before that I tried with linear charger, and disipation was very high.
phoenixdk
pic16f84 ميتر
i dont know to much about that type of battery, but if you want the charger to determin the capacity (Amp-hour), I think I read once that they meaure the internal resistance of the battery, to determine it.
or do you mean how charged the battery is?
bare in mind im not a 100 % sure...
hope it helps a bit
Spirit
Newbie level 5
Newbie level 5
pic16f84 charger
I discharge battery with constant curent until 1V per cell.
I need only to measure time of discharging and calculate battery capacity.
If battery discharge take 10 hours at 200mA, than battery capacity is 2000mAh.
Thats all.
Discharging start-stop are automatic.
Discharging current I can select, so I only need timer wich can measure time of lighting "discharge" LED control signal, calculate t*I and display mAh
phoenixdk
pic16f84 nimh
then you should use the timer module in the mcu ,maybe set it to interrrupt every sec , then program a clock counter using arrays u increment (to meausre discarge time) . you could use the signal from discharge led to initiate counter. it shouldent be to difficult to calc. capacity from known lOad and mea sured discharge time.
if i remember correct the pic16f84 has 2 timers you can use.
but if you want to measure mAh wit mcu then you need another pic, since the one you suggested dont have an A/D converter
SPATAN
Full Member level 2
Full Member level 2
battery characterizer
This circuit is a battery characterizer that applies a fixed load to a charged NiCad or NiMH cell and measures milliamp-hour capacity as it discharges.
Good luck...:D
surfman
Newbie level 6
Newbie level 6
Sofia,Bulgaria
batery charger pic16f84a
Good luck...:D
Can you tell me did you test this project? I need compiled HEX file?
