replacing LM3909 with a 555 timer...?
polag
Junior Member level 2
lm3909
Need help please...........
is it feaseable 2 use a 555 timer in place of LM3909 to produce oscillations and how do I go about it?
wizzz
Junior Member level 3
quebec city
replacement for lm3909
hi polag
check this pdf
it will help you
polag
555 timer for led flasher
thanks 4 the post.
I've seen the datasheet 4 LM3909 already. I want to use a 555 timer both as an oscillator and a led flasher. I can't get the cct right...
on1aag
Full Member level 3
blinking led 555 timer
Hi Polag,
I designed this circuit with the ICM7555 to replace the obsolete LM3909
in a blinking led circuit, or a poor man's alarm system. The circuit was
was designed to operate from a 9 volt battery and to consume as little
as possible. Current consumption is 200 µA and the circuit will continue
to work until the battery voltage drops to approx. 5 volt. No black magic,
I used the charge of the timing capacitor to make the led blink. :idea:
on1aag.
polag
lm3909 replacement
thanks. I'll go and try it.
