bcdonadio
Newbie level 1
Hi!
I've built two power supplies based on this project. They're working wonderfully, but those 2N3055 are simply enormous and require a big heatsink. I've been thinking in replacing them with some MOSFETs, but I'm not sure exactly what should be changed in the circuit. Can someone give me some clues?
If possible, would be good to use some VNP10N that I have (got hundreds of those). They're omnifets, which (if I understood correctly) are MOSFETs with additional protection circuitry in the same die. Here's the datasheet of them: **broken link removed**.
Thank you!
Thank you!
