bobviolence
Newbie level 1
Attached is a picture of a PCB that controls a water softener with the red arrow pointing to what I believe to be the onboard rechargeable battery which helps maintain the system settings in the event of a power loss.
Due to age (10+ years), it will no longer do this, and I'm assuming that if I replace the battery, this will be resolved.
My questions are:
1) Have I correctly identified the battery?
2) If I replace it, will this issue be corrected?
3) Where do I find a replacement battery? (digikey.com?)
The battery has 2 solder points coming off of it.
The only markings on the battery are (in no particular order):
833
1.0F
5.5V
The symbol "M" which is in a boxed circle, followed by GC.
Japan
"-" symbol, presumably for the negative terminal.
My soldering skills are pretty decent, so that shouldn't be an issue.
Thanks in advance.
My questions are:
833
1.0F
5.5V
Japan
Thanks in advance.
