Hello northumber82 ,
I would suggest you could use a 2SA1016 and its compliment 2SC2362,
both are rated at 120V and are made by Sanyo.
If you live in Australia you should be able to obtain them both from either:
Wagner Electronics
2SA1016
2SC2362
or cheaper at WES Components, which are also here in Australia:
WES
When going onto the link above for WES, look right up the top of the page and you should see an
option:
"Online Catalogue", click on that. It will take you to their e-book
type setup. Open the first page and then select, "Electronic Components". Just navigate from that.
Unfortunately the writing is a tad small, but you should be able to see each written component
fairly well. Unfortunately they don't have prices. But both transistors are pretty cheap and available.
i.e. 2SA1016 = $0.74 AUD and 2SC2362 = $0.65 AUD.
I hope the above helps.
Regards,
Relayer
