Re: Replace electric screwdriver's battery to a transformato
I don't understand if you want put it inside the screwdriver...
however you can use a simple transformer of about 40VA 220/12Vac ,a C filter and a zener/bjt voltage stabilizer made by a TIP 41, 2n3055 or other.
The transformer is too big to fit in the cover.
If you cannot have the transformer outside, you must build a primary switching converter which is much mode difficult to design and build respect to the first solution.
