smashrc
Newbie level 3
- Joined
- Jul 26, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 38
Thank you for reading this post
I know nothing about electronic but I am very interested to repair my borken power supply. This power supply is a 2 in 1 design that means it has 2 power supplies built in the same case. You can see the picture, left and right sides are the same. The output of this power supply is 12v 22A each channel.
One day it stopped working. So, I opened the case and see which part is broken. I found the 3 parts are broken
300v 460uf Capacitor is puffed
5D-15 NTC Thermistor is broken
Fuse is blowed
Then I ordered those 3 parts online and replaced myself. Turned on the power supply with no loading, the screen (yes it has lcd screen) said one channel is over load and one is normal. After a few seconds, I hear some clicking sound inside. Then I off the power supply and opened the case for a check up. This time same thing happen, the Capacitor is puffed, the 5D-15 NTC Thermistor was very hot, the fuse almost blowed. It means that the problem is not sloved, it must be something else got wrong to make those 3 parts keep blowing again. As I have no electronic knowledge, I would like to ask what parts should I replace\check to make this power supply back to life. I understand I may not provide enough information here asking for help. So, please feel free to ask me any information if needed.
Last, thanks so much for your help.
Fuse is blowed
