Hello Friends, I am trying to repair a Panasonic Wall ac adapter (6V, 500ma) smps based, I checked with multimeter no output, checked and internal fuse with continuity and all okay, I am attaching pics, im novice so donno what else may be wrong in it, front and back image of pcb with components is attached, at the back there seems to be 2 black spots on some kind of resistance if I can identify properly. Can you all please help me what all I can check and how??
The capacitor, second picture, top center is broken.
Replace it, but most probably you need a low ESR one. Best is if you can replace it with exactely the same type.
Looks like 4 fried resistor, which all need to be replaced and then the board needs to be debugged for why it fried those resistors. The values will likely be important, which means you need the schematic for the board, which is probably going to be difficult if not impossible to get.
